Replacing or Rebuilding Trailing Arms 65 BB
Re: Replacing or Rebuilding Trailing Arms 65 BB
Dan,also Check To See If The E/brake Cable Is Stuck On .as A Last Resort Blairs Does Rebuild You Rear Arms If You Mail To Them. While Apart Check The U-joints, Remember If These Are Orig. And In Are Good Working Order, Leave Them Alone.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
You do not want to exchange those with a vendor, if needed rebuild your original ones. The supports have a date code on them and your arms may be a lot better then any you swap for.
I would look over my thread on this job to give you an idea of what's involved and the correct way to set them up.
As stated you may not have a bearing problem but you want to know.- Top
Bair's is the one place I know will rebuild and send yours back, may be others, but they do a LOT of them. Can also have your dated calipers redone. 814-683-4223 talk to Brian.Bill Clupper #618- Top
Thank you Gary. I read your article with great interest. Thanks again for the information. I'm going to start on the car this coming weekend for the initial inspection and take a look at the e-brake cable. If the bearing(s) is bad, it should be clearly evident via run out? Also, when looking at the u-joints on the half shafts, they too should be easily detected if bad? Can these u-joints be disassembled cleaned and repacked with grease then replaced?? These have no grease zerk on them. 44 years is a long time. Thanks again. Dan K.- Top
Dan,
I would look close at everything as mentioned. If you need U-joints I only use Spicer solids, from 200 hp to over 1000 hp builds. If I can help you just let me know. Don't try and rebuild old joints. I have a thread on joint replacement on the digital site you should look over as well.
- Top
Dan,
Bair's is an excellent choice for getting your trailing arms rebuilt. They have been in the business of building trailing arms (owners originals) for many years with thousands of satisfied customers.
Call Yogi or Brian at 1 800 421-9644 and tell them you have been referred by the NCRS technical board.
Oh yes, that screachhhhhhh your hearing is probably a broken spring on the E-brake shoes. And it's going to ruin your rotor if you don't get it repaired.
JR- Top
Thank you Joe. I appreciate your knowledge on what may be happening with the car.
That's all I need is more to fix/replace. The car is not going to move until I can get under it and start taking things apart. Again, thanks for your help. Dan K.- Top
Dan, the trailing arms may look excellent but, check for a uniform thickness of the metal. If it appears swollen in areas then there is rust. It may feel solid, but it is not. Don't mess with trailing arms. For about $390 + or - you get a new set from Bairs that look identical to the originals. Remember safety first.
- Top
Thank you Harry. Safty is always rule number 1. I won't be moving the car until I can determine just what is going on. This car is worth the time and energy to get the work completed correctly. Thanks again. Dan K.- Top
