Hi, on the firewall of my 68 on the drivers side about where the small white sticker goes..there is a small area that is bare. It lacks the fiberglass mat look and the blackout paint. The area is about 3 inches long and 2" wide or so if I remember (car is in storage)
I am going to attempt to put a little fiberglass mat strand down and some poly resin to regain that fiberglass strand look to that bare area and seal it up with the resin, scuff it a little then paint my firewall (engine is out and finished cleaning up engine bay before it goes back in)
any advice? I have used the bondo brand fiberglass mat and poly resin you get at walmart before when I put a new floor in my ski boat. I coated the new plywood with resin then put some mat down then rolled a layer of resin over the mat..turned out just like the original floor I took up!
anyway thats my only experince with the materials..first off is that the correct materials I'll need for this little project?
I'm just wanting the firewall to have never looked to have had that bare place and in the middle of the bare place is a small indension so I'll have to build that up a bit.
thanks! and I may put a pic of to show the area.
I believe the smooth area is actually the bonding adhesive where it was "tooled" or smoothed along the joint.
