My L-36 is being rebuilt for the first time. I really need your best advice on this one. My mechanic called me today and told me the passenger side of my BB block is ten thou higher than drivers side. He is trying to establish the right quench and CR. He really would like to shave off that 10 thou but he recognizes that is NOT going to happen with my factory broach and stamp pad #'s. So he was trying to find a .032 thick head gasket for the pass side w/out any success. He tried SCE gaskets but they will not work with my application. He is now considering lengthing 4 connecting rods to achieve his goals??. The drivers side is not a problem at .039"-.042" with a thicker gasket.
Duke tell me," this is a common "issue" on OE machined blocks - different side to side deck height/clearance by more than a few thou and using different head gasket thicknesses is the easiest way to solve it." Joe L is not aware of any thinner gaskets at .032" but doesn't rule out somebody might now of some out there
I hope I got this right explaining this too you w/out sounding stupid. Basically the pass side it ten thou higher than the drivers side.
Do you know of a steel head gasket at .032" specs that would work on the passenger side for my application, ie type and company name.
Any advice here is sincerely appreciated.
