Frame Mounting Holes - NCRS Discussion Boards
  • Joel T.
    • April 30, 2005
    • 765
    Hi;
    On my 1963, I have a number of mounting holes which no longer will hold a bolt. These include a couple of the spare tire tub holes as well as a couple of the parking brake cable mounts. I guess this has come from bolt installation and removal over the years.
    What is the conventional wisdom to deal with this? Should I be tapping these out and going with the next size larger bolt? Is there a good source for these "self tapping" type bolts?
    Thanks!
    Joel
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Frame Mounting Holes
    You could go to the next size bolt or there is an insert that goes in similar to a rivit which leaves a threaded insert recessed. You can then thread the correct size bolt. Once in you can't see the rivits. I used this method for the groud wire connection under the transmission mount. I couldn't find these rivits in fine thread and the spare tire tub is held in place with fine thread bolts.
    • Dick W.
      • 10483
      Another good option is heli coil inserts. They are available at most professional parts stores, i.e. NAPA, Carquest, etc
      Dick Whittington
        5/16" Riv-nuts make an excellent and permanent repair in the frame and tank support metal for the spare tire tub bolts; I use aluminum Riv-nuts, as they don't require the special installation tool the steel ones do. Takes ordinary 5/16"-18 bolts, and the Riv-nuts can't be seen with the tub installed.
        • Joel T.
          • April 30, 2005
          • 765
          John;
          Where do you get these?? Should I be able to get them at a local parts store or do I need to go online?
          Joel
            Originally posted by Joel Talka (43778)
            John;
            Joel
            Joel -
            I got mine direct from Arlene at Riv-Nut about six years ago as "Engineering Samples"; they're Part #A31-125.
            Rivnut Engineered Products, Inc.
            2705 Marion Drive, Kendallville, Indiana 46755
            (219) 347-9383
            I use a 5/16"-18 allen-head capscrew and a small-OD AN washer as my installation tool - grease up the threads and washer, run the screw into the Rivnut about halfway, insert it in the hole, and hit it with an air impact gun with a hex driver; that will instantly "set" the Rivnut in the hole - then remove the screw and washer and you're in business.
            • Stuart F.
              • August 31, 1996
              • 4676
              Riv-nuts were, as I recall from my working days, commonly used in original manufacturing processes (not just for repairs), leastwise in the Radiator and Locomotive manufacturing businesses where my experiences were derived. Specially good in light duty sheet metal blind applications. In Locomotives; however, most things are still built on the "Brooklin Bridge" principle which keeps a lot of welders on the job.
              I too keep a handy supply of samples around.
              Stu Fox
              • Michael A.
                • June 30, 1987
                • 41
                Rivnuts can be located form several companies. There are a couple of online locations where you can find more about rivnuts and thier installation tools. I have used them for years and they work great!
                Cardinal - http://www.cardinalcomponents.com/
                Jay-Cee - http://www.rivetsinstock.com/index.html
                Hanson - http://www.hansonrivet.com/articles/rivnut-article.htm
                Enfasco - http://www.enfasco.com/
                Perlane - http://www.perlanesales.com/
                Michael
                Michael Aichele
                MGySgt USMC (Ret).
                Semper Fi
                1975 Corvette Coupe - "Silver/Silver"
                2019 Corvette Convertible - "Sebring Orange Tintcoat" w/Z51
                • Gary B.
                  • February 1, 1997
                  • 6979
                  Frame Mounting Holes; weld solution
                  If you know anyone with welding skills, you can also weld in a small, steel disc to fill in the old hole and then drill and tap.
                  Gary
