54 Voltage Regulator Ground Site - NCRS Discussion Boards
  • Fred L.
    Infrequent User
    • February 1, 2001
    • 3
    I have recently acquired the correct voltage regulator for my 54 with the cover screws through the top of the cover. The one I removed had the screws on the side at the base of the cover. Atached to one of these screws was what I beleive to be a ground wire (uninsulated-braided). My question is what is the correct location for attaching this ground wire on and original voltage regulator - Thanks, Fred
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 54 Voltage Regulator Ground Site
    ]I have recently acquired the correct voltage regulator for my 54 with the cover screws through the top of the cover. The one I removed had the screws on the side at the base of the cover. Atached to one of these screws was what I beleive to be a ground wire (uninsulated-braided). My question is what is the correct location for attaching this ground wire on and original voltage regulator - Thanks, Fred[/quote]
    The VR is ground to the support plate ( that the two screws on the left side take care of that ) it's grounded there.
