I am putting a new Fel-Pro gasket on the oil pan. Can I use the bolts provided or should I use the bolts on the oil pan--they are different. What do the original bolts look like and are they pasinted or unpainted? The four corner bolts I have are unpainted with a raised edge, six sides, a lock washer, and the letters ELH in a double circle. The rest of the smaller bolts are unpainted, 6 sided with a lock collar, and EL in a double circle.
Thanks for your help. Paul
Using longer bolts is definitely easier.
