Also can anyone send me pics of original 63 shifters showing washer/spacer near spring end of cross shaft (3837432) and pin and clip which holds shift handle to cross shaft 542967 and 9412978.
63 Reverse Lever 3824816
63 Convert 340 hp
66 Coupe 300 hp
67 Camaro 1500 hp
00 SS Camaro 320 hpTags: None- Top
Re: 63 Reverse Lever 3824816
Loren,
I thought the shifter stayed the same for both trans. AIM and Noland Adam's book show shifter assembly same for both as 3824815. Trans reverse level and shifter rod do change but shifter reverse level I thought was same.
Thanks Jeff63 Convert 340 hp
66 Coupe 300 hp
67 Camaro 1500 hp
00 SS Camaro 320 hp- Top
I wonder if one of those levers is from some same era passenger car shifter? I know the lever didn't change number for Corvette in 63 when Muncie was used. Same as Warner.I have two 63 shifters with different reverse levers. Short lever is about 2.5” center to center and long level is 2.75” center to center with ITM stamped on inside. 62 and earlier reverse levels are at least 1.0” longer. Any ideas? Does anyone have a print of 3824816 they can email showing dimensions.
In the washer, I think that was a mid production addition to eliminate shifter buzz. (it didn't)
I have a bag of of pins here somewhere and if I can dig it out, I'll get a pic of it.- Top
