Replacing Fan Blade - NCRS Discussion Boards
Replacing Fan Blade
  • Guenter J.
    • October 7, 2008
    • 45
    Replacing Fan Blade
    Any guidance on replacing a fan blade on 1974 L-48 with power streering and A/C. Does radiator have to be removed as well? Thankyou
  • Martin N.
    • July 30, 2007
    • 594
    Re: Replacing Fan Blade
    GUENTER-
    Loosen up the fan clutch to water pump nuts, loosen all of your fan belts that go around the water pump pulley, remove the fan clutch to water pump nuts and washers (if applicable) and remove the Fan / Clutch assembly. The fan will be removed from the fan clutch on your work bench.
    I was at this procedure about 1.5 years ago on my 74 L-48
    Marty
    • Guenter J.
      • October 7, 2008
      • 45
      Dear Marty ,
      Appreciate the answer. Will give a try this wekend.
