65 seat bolts (E) Headmark - NCRS Discussion Boards
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 65 seat bolts (E) Headmark
    Originally posted by Alan Drake (43261)
    Rich,
    Screw 3847757 had a serrated flat washer while the later 3847758 was the same, but NO serrated flat washer. Bet GM had a slipping problem with the later bolt (758) so went back to (757) serrated. (But who knows?)
    Also see Section 11-13 Sheet B7.00 / Think LI has these
    Alan,
    Screw 3847757 must have had a running change somewhere in 64-65. I know that 68-up headlight actuator rod bolts use this part # and they have a non serrated washer. Also the 67-68-69-up front and rear seat mount bolts use this part # and they also are flat washers.
    So now the question is when did the change to the washer take place. I know from most of the bolts that had serrated washers the main useage was for 63 and 64.
    Rich
    • Jim R.
      • June 30, 2001
      • 643
      John i checked my seat bolts today the front ones are GL flat tip and the rears are B&h pointed tip.
      JR
