Exhaust System for a 1960 - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 934
    Would the correct system for a 245HP be the round off-road mufflers with no crossover pipe ? The Corvette Central catalog believes the 245HP had the crossover pipe and oval mufflers.
    Any difference in the quality or fit from the kits sold by Paragon or Corvette Central ?
    Are most buying the aluminized systems for cars that are driven more than judged ?
    How many hours does it take to install these systems ?
    Any gotchas with the installation ?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17549
    Re: Exhaust System for a 1960
    Mark, can't tell you what's correct for a '60. But can tell you the Corvette Central exhaust systems fit well on 57's. When installing put a 1/2 inch plywood shim under pipes where they go through the frame and any other place they might touch. That will provide good clearance and position. Then your good to go to tighten them up. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Rick G.
      • March 1, 1983
      • 270
      Hi Mark,
      My January 1959 car is a 245 hp with I believe still the original exhaust. It has the oval mufflers with no sign of ever having a cross over pipe. It sounds like you are making great progress on your car. Congratulations!
      Best,
      Rick
      • Mark P.
        • May 13, 2008
        • 934
        I think I will go with oval mufflers and no crossover which is completely different than what Corvette Centrals says here for 58-60 cars:
        The judging manual on pg 61 says the crossover was used for 290FI and the 270 engines and pg 84 it says the mufflers were oval for regular camshaft engines and round for high lift. This is consistent with what Rick is saying.
        • Richard P.
          • May 31, 2002
          • 190
          I just finished installing a system from Corvette Central on my '61 and am very pleased. It went together easily and fits and looks great. Cheers.
          • Jim H.
            • April 1, 2002
            • 112
            What system?
            • Richard P.
              • May 31, 2002
              • 190
              Aluminized exhaust with oval mufflers and no crossover pipe (base 230 hp engine)
              • Mark P.
                • May 13, 2008
                • 934
                Richard - how long did it take ? Is it a few hour job ?
                Mark
                • Edward B.
                  • January 1, 1988
                  • 537
                  '60 with 245hp engine would have come with oval mufflers and definitely no crossover.
                  • Richard P.
                    • May 31, 2002
                    • 190
                    Mark,
                    With 2 of us working it took about 4 hours. I got the deluxe kit with all new hangers and brackets and put new ground straps on. We had to cut about an inch off one of the pipes, but other than that it went together nicely. I have an assembly manual(AIM) and had to look at it a few times, but had no problems.
                    Cheers, and good luck.
