Power window switch wiring - NCRS Discussion Boards
  • Bill C.
    • December 1, 1991
    • 177
    On my 67 the left switch lowers the aindow in the forward position and the right switch works opposit, forward to raise. My` question is :Should this be attacked from the console ? I thought about going at it inside the door but the lock button is recessed in the door panal and impossible to use any upholstery tool to remove it without damage to the door panal. All suggestions are appreciated, Bill # 20328
  • Gary G.
    • July 31, 1998
    • 51
    Re: Power window switch wiring
    Checking the console switch would be my first choice. It's the easiest componet to get to and you'll find out quickly if it's fixed or not
    Remembger to disconnect the battery before playing around with it!
