Ok on a 65 the JG manual say's the spare tire tub used 4 recessed 1/2" head 5/16 threaded black phosphate bolts with washers, the assbly manual shows , part# 9420825 for the spare tire tub bolts, ok if thats true that same part #9420825 is also used for the fuel line to frame clips, but we all know these are cad plated ,richard fortier has these in a ad of his in the driveline 5/16-18- 1/2 cad , am i missing something here how can this same part # be cad plated and black phosphate at the same time. and if the bolts were black were the washers also black?.......saddle up bolt lovers.
Bolt guru's try this one!
Re: Bolt guru's try this one!
You know mike i should have phrased that a little different ,i figured that richard would know the correct plating, so i should have said as far as i know they are cad , i just went out to the garage and pulled two fuel line bolts and one brake line and none of them have a e headmark they all have a tiny D in the center with several circles aruond the D ,cleaned them up and they appear to be cad.JR- Top
Jim:
I am not a bolt and nut expert, but I am in the stage of a rebuild of an orignal car that I answer.
Here's what is/was used on my '65 April build .
Tire tub atachment bolts are cad plated, including washer 5/16-18 x .5 inch, 7/8 washer, no head markings.
(They were in good shape and I am reusing those with some cad paint)
I dug out the old fuel line clips and bolts and it is the same size as the tire tub,... (very rusty, no sign of any cad but am not sure) and it has a head marking with a very small "D" and three or four rings around it. I did not re- use these.- Top
Jim --My 5 th edition reads slightly differently [... secured to frame by four black phosphate 1/2" hex-head bolts with integral washers]. No mention of head markings.
Pic below was of a previous post where the consensus seemed to indicate NO integral washers [I'll leave the black or cad finish to you experts]. These are off my early '65 tub.
- Top
The midyear JG's that call for spare tire tub bolts with integral washers are consistently incorrect; 5/16" thread-cutting bolts with separate flat washers were used, as shown in Wayne's photo. A change recommendation has been submitted for the '67 JG.- Top
UH-OH John, does that mean all us guys that hustled around getting the bolts with integral washers are going to have to look for the ones without? Shooter- Top
The originals from my June 67 tire tub (Mar, 1967 date markings)were just like in Wayne's picture with loose washers, black phosphate, but with "E" markings.Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
Whoa, Guys,
for judging purposes, we are placing way too much emphasis on these minute details.
"E" head marks were the most common, others were used.
The real key is the unique slightly rounded outer edges of the bolt head and when properly torqued there is no way to tell if the washers are integral or independent.
With 4 pages to fill out and usually 8-10 cars to judge, if this configuration, finish, installation and completeness appears at a glance to be TFP, an experienced judge will most likely strike a diagonal line through that box and move on.
HaND- Top
