The long-time owner of 53 #276 installed a hot wire - outlet plug setup in the car. As you can see in the attached pic, the outlet is next to the passenger side courtesy light. This outlet powered the dome lights in the custom built hardtop. The outlet also powered a handheld spotlight.
Anybody else running an outlet plug setup in their early Corvette? Roy??
(And yes, I am planning on rewiring the car soon, which will require a great deal of custom wiring. And I will keep the 6 volt setup).
Russ
Russ
I assume it filters the coolant of rust, etc.?? Where is it mounted?
