The fun never ends. I am in the process of converting my dry sump road race 327 to a wet sump motor. I have a melling 155 HV. Have any of you old racers every expirienced a casting failure of the pump. melling warns that when used with solid motor mounts the casting may fail. I don't want to go back and change this out but I will. I'm suspicious that Melling may be trying to sell me the more expensive version of the same pump. Have any of you old racers ever seen a casting failure on this OEM type pump?? Jerry
wet sump oil pump casting failure
Re: wet sump oil pump casting failure
Jerry, only failures that I have seen was from debris, needle bearings from the rockers in both cases, in the pump. I could maybe visualize a harmonic vibration that might do the damage, but that would be a far streachDick Whittington- Top
google: "melling oil pump failure" You'll get a bazzillion hits. On one of the pages I found this:
Here's a link to a page with a couple of pictures that show the difference between the select and regular pumps:http://www.jalopyjournal.com/forum/s...hlight=melling
Jim- Top
Jerry, I just installed a M155 oil pump in my race car. I read the warning that came with the oil pump concerning the potential failure with solid motor mounts. I compared the new pump with several other pumps that I have and it looks like it was redesigned with less mass to the casting.
Dave- Top
make sure you radius grind the area where they machine for the bolt so you have no sharp corners which cause stress risers. you can fab a metal brace from the pickup screen to a main bearing cap bolt or windage tray stud.- Top
