Re: Engine Storage with ATF
Bill, I check humidity by the calipers also. Easiest way to do it.
Pulling the plugs and hitting the starter has the same result oiling as pulling the distributor and using the drill method-correct? If so, this seems alot quicker and easier, IF the shielding is off.
Steve
Steve
