Re: Identify engine sound?
Roald,
Its Tough To Dia. Engine Noises Sometimes, Ive Been Working On Cars For 35 Years, I Can Give You A Few Tips That May Help From Past Gm Experence, Broken Valve Springs Can Be Problem, Gm Uses A Inner And Outer Valve Spring If A Spring Is Broken Its Most Likely The Inner, Another Problem Is A Broken Fuel Pump Internal Spring, Thats Sounds Like A Lifter Sometimes, This Can Can Be Check With A Stethoscope Or A Long Screw Driver Put Tip To Pump Housing And Handle To Ear. Ive Also Seen Cracked Flywheel Problems Where It Bolts To Crankshaft,to Much Flexing When Started Causes This- Drop The Inspection Sheild And Use A Drop Lamp To Inspect,will Need To Rotate Flywhell To Do A Complete Inspection,( By The Way If Your Car Is Manuel Trans. Disreguard).dont Forget If The Noise Is Rpm Sensative It Something To Do With Moving Parts Internal Or External.one Last Thing Its Possiable A Piece Of Carbon Could Have Broken Alway From A Valve And Is On Top Of Piston And Is Contacting Cylinder Head- Gm.s Make Top Engine Cleaner Andthis Is Poured In The Top Of Carb. While Running At Normal Operating Temp.
Roald,
