Engine pad opinion - NCRS Discussion Boards
Engine pad opinion
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Engine pad opinion
    I bought it any way and it don't matter to me , just curious ! Besides few care or know about any 55 because so few are left . And the big advantage of owning a 55 is that it's not a C2.
    • Loren S.
      • November 1, 2002
      • 172
      Can you pull the head, and see if the broach marks run past the pad surface? Inquiring minds want to know!
      • Roy B.
        • February 1, 1975
        • 7044
        #18
        No it's complete and done and I dont care
        • Garry B.
          • January 1, 1991
          • 660
          #19
          Originally posted by Ian Gaston (47813)
          The second "4" and the second "I" ae cock-eyed -- also, the second "I" is a lot lower than the rest of the stamp. I think it's a restamp. I'm not even close to an expert though.
          I am not saying whether this is or isn't original, but the stamp is exactly done the same way '56 models were done. The sixth and seven digit were stamped individually because the gang only holds five digits. For that reason they are almost always misaligned with the first five of the block production numbers. See my two examples below of "56 pads. The edges of the pad are too sharp for my liking though.
          Garry
          Garry Barnes #18531
          '67 Lynndale Blue Coupe- National TF, BG
          ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
          • Joe R.
            • July 31, 1976
            • 4547
            #20
            Good Boy Roy! You bought it because it was a real 55 and you needed a spare.
            Good Decision!
            JR
            • Roy B.
              • February 1, 1975
              • 7044
              #21
              Carry that's what I see all the time.
              • Chuck G.
                • May 31, 1982
                • 2029
                #22
                54 and 55 have the engine stamped with the ENGINE serial number, not the car VIN derivitive.
                That 7 digit number stamp is whacked 3 times. The first 5 numbers are stamped in a gang stamp, and should be aligned.
                The next 2 numbers are stamped individually. That's why you see the last 2 numbers askew in the stamp.
                If they were perfectly straight, i.e., stamped all together in a gang stamp, that would be a DEAD give-away that it's a restamp.
                SO.....alignment doesn't matter in this case.
                Chuck
                • Garry B.
                  • January 1, 1991
                  • 660
                  #23
                  Thanks Chuck. You said it much better than I did. That's why I used pictures to try to tell my story.
                  Garry
                  18531
                  Garry Barnes #18531
                  • Roy B.
                    • February 1, 1975
                    • 7044
                    #24
                    Chuck thanks nice to know you feel it's original
                    • Tom M.
                      • 716
                      #25
                      Originally posted by Mark Pellowski (49021)
                      Ian - here is a 54 pad that was posted on this TDB and most thought it was original. Some letters were held in a gang and stamped and some were done individually. I know by the time they got to 1960 all characters were held in a gang so were straight. Not sure when the transition happened though.
                      Mark
                      THAT THE FIRST TIME I HAVE SEEN A 54 PAD
                      THANKS
                      • James G.
                        • May 31, 1976
                        • 1556
                        #26
                        Here are a couple of original pads Roy.
                        • Kenneth B.
                          • August 31, 1984
                          • 2084
                          #27
                          ROY
                          Not nice to screw with the new guys. See my earlier posts on pad stampings. You got to love the one size fits all stamp pad judging. Not all Corvettes were exact Cookie cutter look alike. Each one was unique. Jim thanks for the pictures.
                          KEN
                          • Garry B.
                            • January 1, 1991
                            • 660
                            #28
                            I'm no expert, but I'm guessing Roy's having some fun. I'm going to guess that this is a new restamp by a pro, but the pad is not aged enough, looks too pristine, like it would when it just came off the assembly line 54 years ago? The edges to the pad look pretty sharp, too, I thought they rounded and/or got nicked up some with age.
                            Loren, I agree with the sharp edged pad. There should also be some pitting on the surface of the pad. I can zoom in on pictures (Mac OS X) about 100x which I did on this pad, and no signs of small pits, scratches, or any other imperfections. Definitely a professional job, but like a bottle of wine it needs some careful aging.
                            Garry
                            18531
                            Garry Barnes #18531
                            • Greg G.
                              • September 30, 1994
                              • 61
                              #29
                              Good pic of the '54 pad. I am doing some work on a '54 now and the pad looks simular, but I have a question. The judging manual says " Six cylinder 235 c.ci. engine had diagonal Machine markings". I don't see them in the picture. Are they there or is the statment about diagonal marks not correct?
                              Greg Gorniak
                              Member
                              Miami Valley NCRS
                              • Loren S.
                                • November 1, 2002
                                • 172
                                #30
                                Here are some pictures I saved of some pads from a restamper that advertised a while back on Ebay. His workmanship looks great, and he even ran his broach marks past the pad. But note that the edges of the pads are sharp, and the absence of age/pitting on the pads:
