I just replaced my engine compartment harnesses (ignition and forward lamp) as well as all of the vacuum hoses. The car starts and runs fine, all lights work, horns work, etc.
I am concerned that a few of my secondary gauges are not working (temp and ammeter). I suspect this is a grounding issue and I will be investigating this coming weekend (my dash was in pieces while replacing the vacuum hoses, fiber optics, headlight switch, etc.).
Years ago the car was converted to utilize an SI style alternator and when I replaced my harnesses I bought the conversion harness adaptors from Lectric Limited.
I have a voltmeter and test light. How can use these to verify the alternator is putting out what it should and charging the battery as the car is running. Is it possible to isolate that possibly the alternator is operating properly but somehow the charge isn't reaching the battery?
Thanks for any replies.
