Need to Tap Into 12 Volt Wiring (1967) - NCRS Discussion Boards
  • Ian H.
    • July 31, 2004
    • 76
    I need to tap into full-time 12 volts. In other words, I need 12 volts even when the car is not running. I will keep the battery charger on for storage longer than a couple of weeks.
    Which wire/location is the best place to make the connection and not be obvious?
    Somewhere under the dash would be my first choice but would go under the hood if necessary.
    I searched but could not find this topic discussed before.
    Thanks.
  • Keith G.
    • October 31, 2006
    • 316
    Re: Need to Tap Into 12 Volt Wiring (1967)
    Just took an alarm system off a newly bought car, they had tapped into the lighter.
    • Dick W.
      • 10483
      Just make sure the circuit has the proper size fuse for the load.
      Dick Whittington
      • Ian H.
        • July 31, 2004
        • 76
        Originally posted by Dave Perry (19643)
        How about the tap on the fuse box? Uses a female spade connector. Will be protected by the dome fuse. I think it's marked 'bat', but is alongside the fuse that protects it. There are other taps as well: accy, ign, and lps (is for dash lights).
        You didn't specify power requirements, but up to about 5 amps or so will be fine at this source.
        Dave
        The power requirement is 1 amp but I didn't want to use the fuse panel since it would be too obvious.
