Are both front spindles the same as far as left and right goes? I thought they were but I see a different casting, A36 on one and B36 on the other..
Front Spindles 1969
Re: Front Spindles 1969
Ned----
The front spindles are the same for both sides for 1969-82 (in fact, they're the same for both sides for 63-67 and 1968, too). These spindles are forged steel pieces. The forging numbers you described likely identify the forging dies that were used. In this case, there were different dies and that's quite common.In Appreciation of John Hinckley- Top
Ned-----
I should also have added that while the spindles are not side-specific, the steering arms which bolt to the spindle are very definitely side-specific.In Appreciation of John Hinckley- Top
