' 63 4657 fuel pump - NCRS Discussion Boards
' 63 4657 fuel pump
  • Michael G.
    • November 12, 2008
    • 2155
    ' 63 4657 fuel pump
    Can anybody verify that the '63 4657 fuel pump listed today as item #
    400034216863 is a service replacement? It has 4657HE stamped on the flange. The listing ends in about an hour.
    Thanks, Mike
  • Michael H.
    • January 29, 2008
    • 7477
    Re: ' 63 4657 fuel pump
    Thanks, Mike
    Michael,
    I'd be VERY cautios. For some reason, the seller never shows the top of the pump. That would be a picture that would tell all. The unique feature of 63 is up there. In the area of the screws that hold the pump together, there are two unique locations on later pumps that have a raised pad around the screw. If the pads are present, it's not an original 63 pump.
    Also, I have to wonder why the seller (Chicago Vette Supply/Al Fierke) didn't show the top that should have AC cast into the top. Hmmmmmmm....
    http://cgi.ebay.com/ebaymotors/ws/eB...rdc=1&viewitem=
    • Michael G.
      • November 12, 2008
      • 2155
      Thanks, Michael. If I recall correctly, JD wrote recently that the two letters after the 4657 meant it was a service replacement, but I couldn't find that quote quickly. Oh well, I'll find another pump somewhere.
      Mike
      • Harry S.
        • July 31, 2002
        • 5258
        I see the auction just ended with the pump going for $105.01.
        I agree with Michael, probably best to avoid that one. Just look for one with the numbers only, no letter suffix's. There are plenty around, don't rush into a purchase. Also look at 63 chevy 409 fuel pumps, you may be surprised at what you find!
        • John D.
          • December 1, 1979
          • 5507
          Michael, Harry is 100% correct. You don't even have to see the pump to know it's not correct for a 63 if the 4657 has a suffix after it. By the way there were many suffixs it seems. That 4657 suffix pump has the frog pads. I saw that listing on ebay and said to myself. What a listing. Looks like it was staged. If you want the real deal pump it typically comes with a very old box. The box is dated and so is the pump. JD
          • Michael G.
            • November 12, 2008
            • 2155
            Thanks guys. It would've been nice if that pump was a correct one, 'cause I'm dressing the engine this week. If I can find a real one soon, I might be able to get it on before the engine goes in the car in two weeks. If not, I can always use my "frog pad" pump for now.
            Look for a post in a few weeks where I'm complaining about a strange "ribbit" sound resonating through the FI plenum...
            Mike
            • Rob M.
              NCRS IT Developer
              • January 1, 2004
              • 12695
              JD,
              I don't think these pumps were dated...
              regards,
              Rob
              Rob.
              NCRS Software Developer
              • Chuck G.
                • May 31, 1982
                • 2029
                Originally posted by Rob Musquetier (41157)
                JD,
                regards,
                Rob
                They are dated, but you've got to look into a little hole and look for a number (2 or 3) and count the hatch marks to get the month. Can't see it "on the car".
                Here are 2 pix, the one on the left has the "frog pads", the one on the right does NOT have the "frog pads" on the top.
                Chuck
                • John D.
                  • December 1, 1979
                  • 5507
                  Mike
                  Michael, The same thing happened to me a few years ago. My 63 FI engine was ready to go back in the chassis. I called my friend Cardina and said don't put the engine in the chassis yet as the fuel pump is a fake. He said we already changed the damn water pump two-three times and now you want to start changing fuel pumps. It was sooo funny. Or at least I thought so. (hope you have the correct water pump)
                  I thought of you today Mike. Our Pittsburgh chapter had a flea market and Dave Kitch and I were talking about the 4657 pumps. He did mention that a typical judge just looks for the AC logos and the 4657. But I am going to guess that is about to change with all the chatter on the forums about the frog pad pumps.
                  When you get the correct 4657 pump rebuilt be sure to buy a rebuild kit that is compatible with ethanol. John
                  • Jeffrey A.
                    • October 22, 2006
                    • 273
                    You are correct. This pump was not dated. They are not the easiest to find either.
                    • Michael G.
                      • November 12, 2008
                      • 2155
                      Looking at my "frog pad" pump, I bet I could put it on my cnc mill and turn those two "pads" into round bosses. Until I can find a real one, I think I might put it on the car like that. (All you judges out there - please forget that I wrote that... )
                      Yeah, my water pump's correct, John, no bushing or anything. I also store my car near an airport, so I'll be stricktly using aviation fuel. That should eliminate any concerns with ethanol, and help with overheating.
                      Thanks, Mike
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Thanks, Mike
                        Would that be a 609 water pump?
                        • Michael G.
                          • November 12, 2008
                          • 2155
                          I don't know the part number off hand, Michael, and the car's not here at my home. I'm pretty sure its correct, but I'll look at the number tomorrow when I'm working on it.
                          Mike
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            Mike
                            Thanks Mike. Just curious. I'm wondering if anyone has a 340/360 HP 63 with an original pump other than a 3782609 casting number.
                            • Michael G.
                              • November 12, 2008
                              • 2155
                              Michael, My water pump is casting number 3859326. According to the JG, this is correct for all but early build 63 L84's (mine's an April build). Please note that this pump is not the original one (I don't know what casting the original pump was), so it should not be used as evidence of actual build patterns.
                              Mike
