I received top flight with my car last fall and have been trying to chip away at some of the minor deductions, I cannot fix one issue and I am looking for H-E-L-P. My top heater core hose that enters the core at the fire wall continues to leak with the proper spring type red clamp. I had a more modern radiator screw type clamp that held excellent but of course this clamp was incorrect.
The bottom clamp holds fine, I have cleaned both the core inlet and tried to ensure a good roundness and lip on the fitting, I also tried #1 form a gasket on the inside of the heater core hose to give additional mating to stop the leak, no luck.
Anyone have a fix without changing the core which is not leaking and working fine.
Thanks, Gary
Thanks, Gary
