68 Ride Height - NCRS Discussion Boards
68 Ride Height
  • Kurt B.
    • July 31, 1996
    • 971
    68 Ride Height
    My 68 which has been completely restored to factory original seems to be lower on the left side than the right.
    I thought it might be the garage floor so I measured from the floor to the fender lip at the center of each rear wheel and the driver side is 1/2 inch lower than the passenger side.
    Can I adjust this somehow so that the car sits level ?
    Thank you in advance
    Kurt
    #26406
  • Terry B.
    • August 31, 1999
    • 607
    Re: 68 Ride Height
    Kurt,
    I am amazed that you can tell a half inch difference from side to side. You have a keen eye. Perhaps it is the shims you used on the body. I did a frame off on my '68 and I think now it sits too high in the rear by about 2 inches however I think it to be level. I guess that is better than too low. The spring will eventually settle out I would think. I hope others give solutions to your problem.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Dick W.
      • 10483
      Re: 68 Ride Height
      Best points to start measuring are the measurements that are in the AIM. They are what the factory used. Make sure those are within spec before you start anything else.
      Dick Whittington
      • Rich G.
        • August 31, 2002
        • 1396
        Re: 68 Ride Height
        My 68 has never had the body off, although it had an extensive body on resto 20 years ago. It only has 36K on it, but it does look lower on the left than the right when viewed from the back. I aways assumed it was just a result of 40 years of driving with few passengers.
        Rich G
