Best way to test a c3 vacuum reservoir tank - NCRS Discussion Boards
  • Robert B.
    • March 1, 1999
    • 43
    Is there a best way to test a 1972 BB vacuum tank reservoir for leaks? I am trying to eliminate the vac tank in my earch for a vac leak.
    Rob
    Re: Best way to test a c3 vacuum reservoir tank
    Rob
    Rob-----
    Very, very easy. Remove all of the vacuum lines from the tank. TIGHTLY cap off one leaving two uncapped. Attach a vacuum gauge to one fittings. Apply vacuum to the other fitting with a Mityvac and tightly pinch off the line from the Mityvac to the tank when you've reached maximum vacuum. Then, observe if the tank will hold vacuum for a reasonable period of time.
    You can also use just the Mityvac with it's attached vacuum gauge, but I have found the above procedure to work best.
    • Robert B.
      • March 1, 1999
      • 43
      Joe,
      I don't have a separate gauge. I have a mighty vac with a gauge. If I am understanding I can cap off two ports and pump vacuum to see if it holds? Is 10HG vacuum good? Thanks.
      Rob
        Joe,
        Rob
        Rob-----
        I'd pump it down to 15-20" Hg. However, if it will pump down to and hold 10" Hg, that should be ok.
        • Robert B.
          • March 1, 1999
          • 43
          Joe,
          I pumped it to 10"HG overnight and it held. I used the center inlet and plugged the two outside holes. So I guess my tank is ok. Off to the relays and actuaters. Thanks for your help.
          Rob
          P.S. If I have a bad check valve off my intake vac line, could this cause an idle issue?
          • Lawrence M.
            • February 1, 1995
            • 404
            Robert, I don't know if the check valve can cause an issue with idle. However, on my 1969 I had an idle issue and after confirming the headlight and wiper vaccum systems were ok the leak was tracked down to the power brake booster.
            Larry
            Larry
            2002 Z51 Convertible
            1969 L46 Convertible
            • Dave S.
              • August 31, 1992
              • 2918
              Rob
              Rob,
              There is a troubleshooting Guide available for these systems.
              • Jay G.
                • April 30, 2001
                • 63
                ...If I have a bad check valve off my intake vac line, could this cause an idle issue?
                Robert,
                The check valve is only in the system to retain vacuum once the car has been shut off. There are many reasons why you would have an idle quality issue but if it is related to the vacuum system, it would be a leak in the system not the check valve.
                Jay
                • Don W.
                  • September 30, 1997
                  • 492
                  Here's the trouble shooting guide; I used it and found 3 items that needed to be replaced....Don
                  • Robert B.
                    • March 1, 1999
                    • 43
                    Thanks - I will continue my vac leak search.
                      • 6940
                      Bob, Vaccum Leaks Are Not Always The Problem, But The First Thing To Check, I Would Take The Air Cleaner Off And Hold Hand Over Top Carb. Leaving A Small Gap Between Fingers If Idle Smooths Out, You Got A Lean Condition ,vaccum Leak Or Fuel Problem .start With Blocking Of One Hose At Time To Eliminate The Problem Of A Hose Leak. Disconnect Each Hose At The Soruce,all Hoses Are At The Intake Rear Or Carburator Base. A Piece Of Electrical Tape Will Work ,unless You A Diff. Size Plugs To Block Off. The Carb Base Gasket Is One Other Source Along With A Intake Manifold Gasket.carb Cleaner Woud Be Helpful Spary A Light Mist At Base Area Of Carb. And If Okay Spary The Intake Manifold At Base,idle Will Smooth Out When You Find Source. Be Careful Not To Go Crazy With Cleaner Its Flamable.
                      • Robert B.
                        • March 1, 1999
                        • 43
                        Thanks - good thoughts. I am planning to try this on the weekend.
                        Rob
