I'm the second owner of a '63 fuel injection convertible which I purchased in 1965. The car had not been modified and all of the ignition shielding was intact. Recently, while looking at the driver's side (LH) exhaust manifold, I noticed that the casting number was 3797902 rather than 3797942 which I would have expected to find. Casting number 3797902 is the correct number for the right side and my car does in fact have a 902 on the right side.
I then realized that the alternator bracket had been ground off of the left side 902. The grinding is extremely well done, with a contour consistent with the curve of the runner and no obvious "grind marks" where the alternator mounting boss was removed. This is obviously not a home shop hack job. Also, the ground surface has a patina consistent with the rest of the manifold.
This car has a very short and mostly known history. Does anyone have a plausible explanation for this adaptation of a 902 manifold to the left side? Factory shortage of 942's? Dealer warranty repair? This occurrence is a mystery to me, but I strongly believe that the modified manifold is "correct for this car." Help me change my mind...
Left side and right side manifolds:
