Distributor Specs? - NCRS Discussion Boards
Distributor Specs?
  • Andrew P.
    • January 4, 2008
    • 36
    Distributor Specs?
    Hello,
    Could someone with a 1974 Chassis service manual please post the distributor specs for dist #1112526 (454, 270hp). Its under the Specifications section of the manual. Or if anyone has these specs that would be great.
    I searched the archives and 1112526 doesn't come up.
    Thanks in advance,
    Andrew Papanicolaou
  • Robert E.
    • April 1, 2004
    • 398
    Re: Distributor Specs?
    Andrew,
    Sorry, I don't have the specs, but there is an NOS example on ebay.
    Robert
    Originally posted by Andrew Papanicolaou (48361)
    Hello,
    Thanks in advance,
    Andrew Papanicolaou
    • Wayne M.
      • March 1, 1980
      • 6414
      ...please post the distributor specs for dist #1112526 (454, 270hp). ...Andrew Papanicolaou
      From Delco Remy Test Spec's book DS-324S-1:
      points opening 0.016"
      centrif. advance; 0-2 deg adv. @ 650 rpm
      4.5-6.5 deg. adv. @ 1200;
      max centrif. 8-10 deg. @ 2100 rpm
      Vac advance Can: # 1973437; start adv. 7-9 " Hg vac.
      8 deg. (disrib.) max. adv. @ 16-18 " Hg.
      Note: distrib. advance degrees and distrib. RPM are one-half engine RPM and crank degrees of advance.
      • Andrew P.
        • January 4, 2008
        • 36
        Robert, thanks for the heads up on the dist on eBay.
        Wayne, thank you for the specs!!! Does your book list the specs for dist 1112050? If so, do you mind posting them?
        Thanks again for your time and help,
        Andrew Papanicolaou
        • William C.
          • May 31, 1975
          • 6037
          From the delco remy spec book, 1112050 is 0-2 @650, 4.5-6.5@1200, and 8-10 @ 2100, all distributor degrees and distributor RPM, multiply X2 for engine equivalent numbers. Vacuum can part number 1973437
          Bill Clupper #618
