I did a search and read all the good info about the correct steering gear lube to use in my '73. I searched the GM electronic parts manual starting with p/n 1051052 and as others have mentioned it is obsolete and dead ends before any reference is made to 12377985. The p/n recommended by people here is 12377985. The tube identifies the contents as "chassis grease" and the '73 repair manual states not to use EP chassis grease in the gear box. Realizing that 1973 was a long time ago perhaps the grease is formulated differently and higher tech.
In any event what was in my steering box was black and very viscous like about 80W or 90W oil and not very much of it. Could that have been original? I used a big big seringe my wife (the nurse) brought home and injected 120cc (4 oz) of the grease into the bolt hole in the top of the gear. I used the upper bolt hole but I would recomment using the lower bolt hole to fill. You can't overfill and have to leave room for airation and expansion. The repair manual states not to overfill but doesn't say anything about what "full" is.
Anyway here's a pic of what I did that might help others. Following the fill I adjusted the worm gear and end bearing clearances and rebuilt my steering column and things feel really good now. My steering use to be very sloppy, clunky and noisy.
