My car started out in life as a 1968 427 390hp non AC car, and over the last year, I have found and installed all of the hard to find 1968 only AC parts in the interior and the correct 68 only evaporator case assembly. The remaining job that I have left is to install the correct 68 only big block AC radiator core support, correct condenser and mounting brackets, and correct AC lines with the correct hose clamps which I have already collected. Even though the parts cost much more, I could not stand the thought of installing an aftermarket JIP AC system even though it would have been at a 1/3 of the cost in parts of what I paid. Recently I picked what I was told and appeared to be the correct AC Radiator Core Support according to the 1968 Corvette assembly manual for my 1968 Corvette 427 390HP. While this unit has the correct 1968 condenser AC line holes and the correct brass copper radiator support mounts for my existing new 427 radiator, I don’t see three out of the four holes required for mounting my original fiberglass 427 fan shroud. On AIM UPC L36 A11, the bottom hole below item 4 appears to be the correct lower fan shroud mounting hole which is on this core support but the remaining three are missing. On AIM UPC L36 A11 lower right this hole has a line pointing to it and it shows 7/16 + - 1/64. Also, on AIM UPC C60 B1, the original 68 condenser correct mounting brackets line up with all of the existing holes which is good. End the end, maybe this 1968 AC core support was used for a slightly diffent application but I'm hoping that you will tell that drilling the remaining three holes will make it correct for my applcation. In addition, I got the impression from the assembly manual that the non AC and AC 427 390hp fiberglass fan shrouds are the same so I’m hoping that you can confirm if this is correct. Furthermore, I have attached a picture of the core support so you can get a better idea of what I’m talking about.
Thanks!
Joe
Thanks!
Joe
