A couple of weekends ago, my 69 flooded out and I had it towed home. Investigating, I installed a spare rochester and it also ran with flooding symptoms. I replaced the needle and seat in the original carb, set the float and reinstalled it and it still floods. So I attached a fuel pressure gauge and it read 9psi. Book says 5.5 to 6.5 at idle speed. Before I ordered a replacement fuel pump (I'm pretty sure the one that's on it now is not the original anyway), I thought I'd blow through the return line and make sure it wasn't blocked. There is some back pressure on the return line and I can hear the gas cap vent hissing but I have never done that before on a perfectly operating car, so I don't really have a frame of reference to know how freely that line should flow. I kinda suspect its fine, but not 100% sure. Anything else I can do to confirm thats its a fuel pump problem? I haven't looked at the filter, but logically I can't imagine that to be a the problem. Advice?
Fuel Pump Pressure & Return 69'
Re: Fuel Pump Pressure & Return 69'
take the cap off and blow thru the return line with 5# of pressure,no more as it could blow the lines off of the tank. what you see is what happens when that return line gets plugged. the return line is a "pressure leak" and you will see 9# if the line is plugged. if your fuel pump goes "bad" on the road just clamp off the return hose and you can drive home. been there done thatA couple of weekends ago, my 69 flooded out and I had it towed home. Investigating, I installed a spare rochester and it also ran with flooding symptoms. I replaced the needle and seat in the original carb, set the float and reinstalled it and it still floods. So I attached a fuel pressure gauge and it read 9psi. Book says 5.5 to 6.5 at idle speed. Before I ordered a replacement fuel pump (I'm pretty sure the one that's on it now is not the original anyway), I thought I'd blow through the return line and make sure it wasn't blocked. There is some back pressure on the return line and I can hear the gas cap vent hissing but I have never done that before on a perfectly operating car, so I don't really have a frame of reference to know how freely that line should flow. I kinda suspect its fine, but not 100% sure. Anything else I can do to confirm thats its a fuel pump problem? I haven't looked at the filter, but logically I can't imagine that to be a the problem. Advice?- Top
