Doing the final assembly on my early 61 with a top tank radiator. Looking for the correct bolt length and the size of the rubber pads that are between the side brackets and the core. Thickness, length and width. Also are there 45's cut in the pads as are in the side brackets? Thanks in advance.
60 early 61 Top Tank Radiator Help
Re: 60 early 61 Top Tank Radiator Help
paul, send me your email address and i'll send you some detailed photos of some original pads and bolts, cfaber@cox.net- Top
Why not post them here for all to see and use for future reference?paul, send me your email address and i'll send you some detailed photos of some original pads and bolts, cfaber@cox.net- Top
[quote=Jim Durham (8797);405563]Why not post them here for all to see and use for future reference
the material looks like thick a inner tube and measures 1/8 of an inch, [ .125 ]- Top
