1965 Judging Manual Question - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 934
    Can anyone with a 1965 Judging Manual tell me what it says about a 1965 master cylinder without power brakes. I ordered a JM but have not yet received it.
    If I get an original one with the 2225032 casting number with a body and cap painted gloss black will this pass judging ?
    Is the 3 digit code under the clip mentioned in the JM ? Seems like it could be a Julian date but it is not confirmed on this discussion board.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1965 Judging Manual Question
    Mark -- yes to what the '65 5th ed. manual says about your 2nd paragraph. Doesn't mention date.
    Was going to reply to your earlier post, but will add my 2 cents here. I have two '65's; the early one #014xx has the master cylinder shown in the pic [taken with a mirror, then digitally flipped]. The cast # is 618967 (not 2225032, per the JG). It also has the Bendix symbol just like my late car (which does have the cast # mentioned in the JG). The M.C. has a Julian (?) date of '183'.
    After learning a few years ago that the 222... # was the accepted correct #, I'd just assumed that the other # was a Bendix service replacement. Don't want to start a controversy, but am now wondering if the 618967 is early production . Apart from the casting numbers, the two master cylinders look identical.
    FWIW, the GM parts book says the master cylinder part # is 3866446 (Bendix # 618690).
    • Mark P.
      • May 13, 2008
      • 934
      Thanks Wayne. I just bought a resleeved and restored 2225032 with a 284. If this is a Julian date this would be Oct 14.
      Whatever the 284 actually is, this MC should judge correctly then.
      Glad the 284 isn't judged because I am not sure if an Oct 64 casting was also 2225032 and was installed in a 2/4/65 car.
      I'll keep this issue in mind if I see a Bowtie car.
      • Loren L.
        • April 30, 1976
        • 4104
        Gloss Black?
        • Mark P.
          • May 13, 2008
          • 934
          I meant semi-gloss paint for the body and cap. Is that right ?
          • Mike M.
            Director Region V
            • August 31, 1994
            • 1464
            Right, Mark. S-G Black.
            HaND
