1967 parts help - NCRS Discussion Boards
1967 parts help
  • Jeremy H.
    • January 1, 1999
    • 260
    1967 parts help
    Does anyone know where I can get the correct hardtop plugs? (they go in hole where to hard top mounts on the top of the rear deck when the hard top is not in use) Also where I can get the two nuts that mount the pedal assembly to the firewall? These are not the studs that the master cylinder mounts on but the two studs right above them.
    Jeremy Hedges
    #31711
  • Bill M.
    • 1317
    Re: 1967 parts help
    jeremy
    I have always had good luck with Long Island Corvettes . I bought the hardtop bolt set from them last year. 1 800 466 6367
    Bill
    • Mike E.
      • February 28, 1975
      • 5134
      Re: 1967 parts help
      Corvette Central has the HT plugs in their catalog.
      • Henry S.
        • April 30, 2005
        • 816
        Re: 1967 parts help
        Jeremy, I will have to look when I get to the shop but I bought a set a couple years ago from one of the vendors (not sure if they are correct for judging or not). But if you are planning on judging the car if you have or can look at the "Fact Book of the 1963-1967 Stinrgray" by M.F. Dobbins on page 362 there is a picture of the hardtop rear deck carriage bolts with the original and GM replacement. Shooter
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1463
          Re: 1967 parts help
          Hi Jeremy,
          to clarify, the vacant bezels did not have plugs. The hardtop bolts with rubber gaskets were removed from the rear of the hardtop and bolted into the "Holes"
          HaND
            Re: 1967 parts help
            Jeremy -
            The snap-in stainless plugs the vendors sell are "pretty", but not correct - GM never used them.
            As Mike noted, you use the hardtop bolts, and add the two rubber sealing washers between the bottom of the bolt heads and the bezels. Those washers are item #23 in section C07, sheet A6 in the Assembly Manual, which are shown in the Miscellaneous Shipping List in UPC 0; those two washers were placed in the cloth bag with the hardtop wrench in the glove box when the car left St. Louis with the hardtop installed. The instructions for installing them after removing the hardtop are in the owner's manual, under "Hard Top", on page 29.
            If the car is presented for judging with the hardtop in place, the judges will expect to find those two rubber washers in the cloth bag with the wrench in the glove box.
            • Wayne W.
              • April 30, 1982
              • 3605
              Re: 1967 parts help
              I know what the literature says, but I still find it hard to believe that anyone would use those bolts. First of all they were not finished well. Mine have grinding marks on them. Secondly, they are retained in the slots on the hard top with dum-dum. Nice and messy. I don't think that many would have been used in that application. The side bolt is a more likely candidate.
