Spotted this last weekend while doing the normal spring inspection. Appears to be a crack in the rubber sheath of the power steering high pressure hose.
As you can see, the hose is dry, so there's no leak - yet.
Is this in danger of immediate rupture, or do I have a little time?
BTW - I assume that the hose clamp on the low pressure hose probably isn't correct. Comments?
Randy
Randy
