Re: Diameter of 1977 Antenna ball
Dale:
You can't go into your local Home Depot and buy a .300" (actually 29/64) with the correct size hole drilled to accept the mast. However- I happen to have a supply of these WITH the hole drilled perfectly centered to accept the mast (don't ask why). If you send me your mast I will knock off the 1/4" ball and retrofit it with the .300 ball for the cost of the ball and shipping. Antone else needs one I will do it for you until the supply is gone (I will make no profit, just for cost so this is not an ad). Glad to help.
Jeff
Dale:
Jeff
