Need help locating ww tires. - NCRS Discussion Boards
    • November 1, 1991
    • 146
    Has anyone found a source for the correct width, or within 1/16", for a whitewall radial tire to fit a 62? I've checked all the usual places and can't locate any. My tires are 16 years old and although the car is always garaged, I have some concern the tires should be replaced due to age only. Less than 3000 miles on them.
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Need help locating ww tires.
    Did you try the diamondback tire web site?
      www.dbtires.com
      They'll put any width whitewall you want at any distance from the bead that you want; all brand-new brand-name radial tires made in modern high-volume tire plants.
        • November 1, 1991
        • 146
        Thanks. Technical judging guide says 7/8 to 1 1/16 width, but what was the distance from the bead?
