I am ready to install the o/s mirror on my '58, but I can't find any measurements of the exact location on the driver's door to mount it. any help would be appreciated.
58 outside mirror location
Re: 58 outside mirror location
Ron,
Your 58 came with only one mirror so how many holes do you have in the door anyway?
If there is only one set of holes, that has to be them. There should also be a nut plate on the inside of the door for the mirror.
JR- Top
Joe, thanks for your answer, but the holes in the door were repaired during the painting process. the mirror that had been installed had larger bolt pattern that the corvette mirror I bought to install. I can't understand why someone would have done this, the rest of the car had no modifications. thanks- Top
Ron,
Look under with a flashlight and mirror. That should tell you something. If the hole pattern is different you should find a new set of holes. If there is only one set of holes it has to be the originals.
JR- Top
Ron:
Here are measurements from my '59:
The front pencil mark is 2-1/2" back from a square corner
The rear pencil mark is back 3-5/32" back from a square corner.
The front hole is 1-31/32" from the edge using a square as shown.
The rear hole is 1-7/8" from the edge.
The holes should be 1-3/4 apart; if not, something is wrong.
The holes are 1/4"
By "square corner" I am trying to eliminate any rounding of the fiberglass at that leading edge.
BillAttached Files- Top
My 1958 Outside Mirror - The front leading edge of my mirror base is 3" from center of the front door edge / gap with front fender and 2" center of base from top of door by the door post... no deducts at 2008 Nationals at St. Louis....Ron:
The holes are 1/4"
BillRegards,
Brady Como
#42793- Top
