Borg Warner T-10 Bearing Retainer - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    What would be the application for a T10A-6A bearing retainer and will it work on a 1961 C case BW T-10?
    Thanks for any information!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Joe R.
    • July 31, 1976
    • 4547
    Re: Borg Warner T-10 Bearing Retainer
    Ray,
    You need a T89B-6 for your T-10. The T10-6B is longer, has the same size bolt pattern and bellhousing hole size.
    JR
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks! JR
      Ray
      Ray Carney
      • Joe M.
        • February 1, 2005
        • 589
        What is the actual difference in length between the two retainers and how does it impact function?
        Joe
        • Joe R.
          • July 31, 1976
          • 4547
          Joe,
          The 10A-6A is 1/2 inch longer. I have no idea if it would work or not but I wouldn't want to install it to find out. It would limit travel of the clutch disc by the above amount.
          JR
          • Clem Z.
            • January 1, 2006
            • 9427
            there were some 4 speeds out there that had aluminum front bearing retainers and these should never be reused as they cause the T/O bearing to stick in its travel. don't know if any corvette 4 speed trans had this or not.
            • Joe R.
              • July 31, 1976
              • 4547
              Clem,
              As a matter of fact, all 1963 transmissions had an aluminum bearing retainer. That's T-10's or Muncie's! Probably because of the small hole in the 621 bell housing. And I have never seen one that was not nearly worn out!
              JR
              • Ray C.
                • June 30, 2001
                • 1132
                Joe,
                Are there any other differences between the bearing retainers? I have access to a metal lath and can machine off 1/2" from the T10A-6A.
                Thanks for your help!
                Ray
                Ray Carney
                • Joe R.
                  • July 31, 1976
                  • 4547
                  Ray,
                  There is a hole missing on the longer one but I don't think it would be of any significance in operation. The T-10 retainers have a hole in the bottom rear near the flange. Don't know the reason for the hole. Could be that it might throw a little lube on the throwout bearing but I don't think so. Just don't know about that.
                  JR
                  • Ray C.
                    • June 30, 2001
                    • 1132
                    Thanks! Joe
                    I just purchase the correct one.
                    Ray
                    Ray Carney
                    • Ray C.
                      • June 30, 2001
                      • 1132
                      Joe,
                      For your knowledge, I just received an aftermarket T10-6B front bearing retainer and it is almost identical to the T10A-6A. You were correct on the additional 1/2" in length. If one was to mill 1/2" off the T10A-6A retainer I am sure it would work.
                      Ray
                      Ray Carney
