My base plate does not have the mount for the lobe sweep pad. There is a small rectangular slot on the plate with small burrs around the edges leading me to believe it once existed there before Bubba got to it. I will get a replacement plate provided the sweep was not eliminated at some point in production. Any thoughts? Thanks, Mike
71 Distributor question
Tags: None
- Top
Re: 71 Distributor question
If you're talking about the lubrication felt wick (later a polyurethane foam cylinder) I believe one of the Corvette parts houses offers a replacement, but I've never found one through the major electrical replacement part manufacturers like Standard Motor Products, nor have I found replacement breaker plates - the one major single point distributor part that does not appear to be available.
Duke- Top
You don't really need a new plate, the slot is for a nylon clip that holds the wiper, just snaps into the hole.Bill Clupper #618- Top
Thank you Duke and Bill. The only memory I have from the points and condensor days was a two prong metal fork type tiny bracket that was fused to the points plate and the felt was forced between the prongs.
Thanks for the info. Mike- Top
Michael -- here's an NOS plate with points (pkg. originally had the 2 clamshell shields [viz. 2 extra screw holes]).If you're talking about the lubrication felt wick (later a polyurethane foam cylinder) I believe one of the Corvette parts houses offers a replacement, but I've never found one through the major electrical replacement part manufacturers like Standard Motor Products, nor have I found replacement breaker plates - the one major single point distributor part that does not appear to be available.
Notice the nylon mount for the foam wick cylinder, which is missing (in this case). You just squeeze the 2 forks of the clip to remove or insert in the rectangle of the baseplate, as Bill says. Don't know whether this part still checks out in the General's supply.
- Top
Thanks Wayne. The picture helps very much. Paragon offers the cam lubricating wick w/ mount. No picture in the catalog. I'll get one until I have exhausted all efforts to find NOS. Thanks again, Mike- Top
