This evening I told my wife I wanted to pull the body off and restore the chassis (1972 350/300 auto Coupe). Her standard question then came out, i.e., "What's that going to cost????"
Ok, I thought, well that really is a good question. Soooo... Can someone throw out some ballpark numbers from their experience assuming:
1. I do all the work myself with the exception of TA rebuild, dipping the frame to remove rust, and any sandblasting that may be required.
2. There is light to moderate rust on most surfaces but I don't believe any components or frame sections will need to be replaced.
3. Replacement of brake and fuel lines.
4. Everything else that needs to be done to a 71k miles car that obviously has never had any previous attention to the underside of it.
5. All parts and finish are to be to NCRS standards.
I know that it really is impossible for anyone to give an estmate with any accuracy having never seen it. But just knowing the ballpark range of costs from those who have already done it would be beneficial.
