Replacement VIN - NCRS Discussion Boards
Replacement VIN
  • Dale C.
    • November 1, 1999
    • 844
    Replacement VIN
    Good story about the replacement of a VIN in last Restorer. What's that about pulling off left rear wheel an geting a pencil rubbing in the narrow space between the metal and fiberglass? Have not seen much on this. Is this on all cars?
    Dale
  • Steven S.
    • August 29, 2007
    • 571
    Re: Replacement VIN
    That is the location where the VIN is stamped on the frame on all C2's (and possibly C3's?). Very hard to read with the body on frame.
    Steve
      • 15573
      Re: Replacement VIN
      Yes -- C3s also
      • William G.
        • January 1, 1988
        • 220
        Re: Replacement VIN
        I have attached a photo of my frame numbers for my 66 roadster #23590. It is not easy to do with the body on but can be done assuming your frame isn't badly rusted. I used a specially cut mirror about 1 inch x 6 inches with a flexible handle made of tape attached to it. After cleaning the area and finding the numbers its a matter of using some dum-dum or plumper's putty to hold the mirror in position to photograph. You will need a digital camera with a macro setting and you will need to try different camera angles and lighting. This shot took at least 20 tries. It is a lot of work but with a definite payoff.
        • Vincent F.
          • August 31, 2006
          • 202
          Re: Replacement VIN
          I can see mine (71) with a small mirror and flashlite, top side of frame above left rear wheel, also stamped on top frame rail under drivers door,very hard to see.
