I'm working the rear of the car....fuel tank, rear suspension etc....
When I removed the rear wheels, it was evident that the rear rotors had been off of the car, and the rear spindles both appear to be aftermarket...( they have a gold colored tint ).
After removing the half shafts, the rear bearings felt smooth, and sounded quiet when rotated...I didn't put a dial indicator on the hub.
Upon removing the spindles to inspect the bearings, the grease was clean (no shavings or grit), the bearings looked good, and the races didn't show any signs of "hot spots"....even the seals looked good and tight. Previous owner can't give me any particulars in terms of when the work may have been done.
Here is the question: clean, repack, and reinstall, or change the bearings and seals with new ones?
