1971 CEC solenoid bracket - NCRS Discussion Boards
  • Thomas H.
    • August 31, 2005
    • 1053
    It took some time, but I finally found a correct solenoid, at the right price, for my 71 LS5 CEC system. Very timely since there was a great
    Restorer article about the system.
    I now have everything I need to get the system up and running except....... The solenoid bracket and the solenoid nut. (A nut came with the solenoid, but I must have put it in a safe place so I wouldn't loose it.........)
    Is the bracket the same as the ones used on later carbs to support the solenoid?
    Any suggestions are appreciated.
    Tom
    2007 Z06, Lemans Blue
    Re: 1971 CEC solenoid bracket
    Tom
    Thomas----
    The solenoid bracket for your application was used for 71-74 Corvettes with Rochester Q-Jet carb and utilizing a solenoid as well as most other 71-73 Chevrolets with Q-Jet carb and utilizing a solenoid.
      • 11608
      Thomas----
      I've purchased passenger car Q-jets for low prices just to get the bracket. Even more rare is the correct screw that holds the bracket to the carb.
      • Thomas H.
        • August 31, 2005
        • 1053
        Thomas----
        Thanks Joe.
        I'll go search the garage an see what I have sitting around.
        Tom
        • Thomas H.
          • August 31, 2005
          • 1053
          Patrick,
          Taking Joe's advise I went searching around the garage. Found a bracket along with what I think is the correct screw. What do you think?
          Part number on the bracket is 42682
          Tom
            • 11608
            Ding! Ding! Ding!
            We have a winner!
            Nice condition, too.
              Patrick,
              Tom
              Tom-----
              "42682" is not the part number. However, it is a DERIVATIVE of the part number which is GM #7042682. That is the Rochester Products Division-assigned GM part number for the 71-74 Corvette with Q-Jet solenoid bracket.
              • Thomas H.
                • August 31, 2005
                • 1053
                Ding! Ding! Ding!
                We have a winner!
                I have a box of old Quadrajet parts from carbs that have been scrapped over the years and once you mentioned a "special screw" I immediatly remembered I had one of them somewhere. Didn't take long to find it!
                Tom
                • Thomas H.
                  • August 31, 2005
                  • 1053
                  Tom-----
                  Thanks Joe.
                  I now have all of the pieces to the CEC puzzle. Time to start putting it together.
                  Tom
