I have been using CJ-4 oil, such as Shell Rotella in my 1965 Corvette with L76 for a few years now, but I no longer want the higher viscosity 15W-40, because I plan on using a standard pressure relief spring in my oil pump. This engine will regularly see 7000 RPM operation.
I would like to use a multi viscosity oil with 30 as the op temp weight, which is not available in CJ-4. Prefer to use a 5W-30 with 10W-30 as a second choice (the engine never sees operation below 45 degrees F).
3.1 ounces ZDDPlus added to a 5 quart volume of SM oil will provide optimal zinc concentration of about .14.
