70 L46 Crank Bolt and Crank Pulley bolts - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    I was reviewing the AIM as I was about to put the crank bolt back and then bolt the pulley to the balancer. The AIM indicates that both the crank bolt and pulley bolts have lock washers. Neither had them when removed. Did the factory install lock washers?
    If so, what size/thickness am I looking for since it appears these were installed at the engine plant so part numbers are not called out in the AIM?
    Thanks as always for the help!
    Bill Lennox
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 70 L46 Crank Bolt and Crank Pulley bolts
    Bill,
    the crankshaft balancer bolt had a externaly toothed star washer and the crank pulley bolts had regular SAE size split ring lock washers.
    Rich
