Are there any negative effectives to using two different strength springs in the distributor to control centrifugal advance?
In order to get the idle timing to 12 BTDC when using the two medium springs I must turn the distributor which lowers the rpm and decreases the idle quality. I can open the carburetor throttle plates to increase the idle rpm and have better idle quality, but then I start having minor amounts of dieseling when the engine is turned off.
Roger
Roger
