Re: (help!!) Information On 1972 Vette Anti Theft Alarm System
If the diaphragm is rusted through, unless you can find another diaphragm it is toast. You may not be able to tell the condition of the internal pieces until you get it apart.
The rivets have to be ground down on one side and then pushed out with a punch. They can be replaced with small screws, but the screws have to be really tight (and stay that way) for the horn to work and sound the right tone. Once the screws are in tight, and you know the horn is working, the slot in the head of the screw can be filled in with caulk and everything painted.
Of course there is always the chance the electrical circuit in the horn is damaged, and then one would need donor pieces from another horn.
There are folks who fix horns who advertise in The Driveline. Ask them if they do alarm horns. The learning curve may be too steep, and parts amiability too difficult for the armature.
