1963 Aim - NCRS Discussion Boards
1963 Aim
  • Steve D.
    • February 1, 2002
    • 990
    1963 Aim
    1963 convertible_ In my 63 AIM __ Sec C60, plate 5, item 18__ the part number is blank. Perhaps someone has an AIM that has the part number identified in it. It is for the crank pulley to be used with AC installed.
    Steve
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 1963 Aim
    Steve:
    Seems to me that parts not installed at St. Louis were not called out by number in the manual. Joe will pop in and assist on this one, I'm sure.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
      Re: 1963 Aim
      Steve
      The symbol indicates that it attaches the same as the base-car pulley, but the part number is in the C60 section of the Engineering Parts List (which was never released outside of GM). I believe it may be P/N 3744043.
      • Steve D.
        • February 1, 2002
        • 990
        Re: 1963 Aim
        John, thank you.
        3744043 is the number in my AIM for the base configuration crank pulley, and I have that pulley.
        Related question_ on the same sheet 5, a number is given for a generator pulley (1949355) that is different from the base configuration (1958095). I have an aftermarket alternator instead of the generator. How likely is it that the specified generator pulley would fit on the alternator and give the propert alignment? I can see that something will be required to align the alternator belt. Alignment was fine when the alternator was on the passenger side, but since I moved it to the driver side for the AC install, it is requiring alignment.
        steve
        • Timothy B.
          • April 30, 1983
          • 5177
          Re: 1963 Aim
          Steve, Here is a pic of a 63 air condition alternator pulley. It's the only pic I can help with and it shows the arrangment of the belts.
          • Steve D.
            • February 1, 2002
            • 990
            Re: 1963 Aim
            Timothy
            Thanks. Pictures always help.
            Steve
              Re: 1963 Aim
              I have an aftermarket alternator instead of the generator. How likely is it that the specified generator pulley would fit on the alternator and give the propert alignment? steve
              Steve -
              Although the Assembly Manual sheet calls it a "generator", it was always an alternator from '63-up. At that time, the word "alternator" was trademarked by Chrysler (who invented it), so GM called it an "AC generator", then the "Delcotron".
              • Stuart F.
                • August 31, 1996
                • 4676
                Re: 1963 Aim
                I would have thought "Generator" and "Alternator" were generic electrical industry terms - used long before the auto industry got a hold of them. I'll have to go back into some of my old text books.
                Stu Fox
                • John D.
                  • December 1, 1979
                  • 5507
                  Re: 1963 Aim
                  Steve -
                  I took the United Delco Courses at a GM training center outside of Pittsburgh in 61 and 62. We had to learn all about the new Delcotron.
                  Haven't heard that term in a long time John. JD
