Having wiper door issues. Tested with a hand held vacuum test pump and proved the side of the wiper door actuator that "opens" the door loses vacuum very quickly. I suspect the seal on that side of the actuator is faulty. Paragon sells a replacement seal (see below)
Has anyone ever replaced one of these seals? If so, is it easy to do and also what have been your results?
Sorry folks, I know I always "ask" the questions. But once I learn enough from you guys then maybe I'll be able to actually "answer" a question or two someday
