Most of the bonds between my hood skin and the inner frame are broken. I have removed all loose caulking, cleaned the surfaces to be joined and have obtained a tube of non hardening polyurethane caulking. I have also masked off the surounding surfaces.
Past posts have suggested that weight be applied to the hood while the caulking cures. Applying weight deforms the shape of the hood. I am concerned that the hood won't match the fender openings if the caulking is allow to cure while while weights are on it.
Any recommendations/comments?
Thank you,
Randy
Thank you,
Randy
faint spider web on top.
