birthday - NCRS Discussion Boards
birthday
  • John V.
    • January 23, 2008
    • 4
    birthday
    Hi I have 1972 Coupe
    I need to find out the birthday of my vett, Vin 1Z37K2S512629 and alo Exhaust manifolds Cast Numbers so that i can find the correct ones.
    regards John
  • Steven B.
    • June 30, 1982
    • 3976
    Re: birthday
    regards John
    John, per the Birthday Book, 6th ed., #2629 was assembled Friday, Sept. 17, 1971. The last one assembled that day was #2689 and the first one was 2578.
    Steve
    • Bill E.
      • February 20, 2009
      • 38
      Re: birthday
      steve I HAVE THE CORVETTE BLACK BOOK AND ENDIND VEHICLE SEPT. 71 503697 JAN. 72 512661 I THINK JOHN CAR IS BUILT INTHE LAST WEEK OF JAN. 1972
      • Steven B.
        • June 30, 1982
        • 3976
        Re: birthday
        Hi Bill! I dropped a "1", the most important one! #12629 per the BDB was Mon, Jan 31. The first car that day was #12550 (providing no week end OT) and the last #12661.
        Thanks for catching that!
        Steve
        • Roy V.
          • April 8, 2008
          • 296
          Re: birthday
          John, according to the 4th edition of the 1970-1972 NCRS Technical manual (which I strongly suggest you purchase, as it is the best resource for all the correct information for our cars).
          1972 base engine casting numbers are divided into 2 categories (early and late) I'm sorry I don't know when the cutoff is.
          Early drivers side - 3989036
          Early pass. side - 3989036
          Late drivers side - 3932461
          Late pass. side - 3932461
          *those 200 hp (base engine) Corvettes delivered for sale in California were required to be equipped with NB2 which included among other items AIR (Air Injector Reactor), therefore, those manifolds were drilled and tapped for the AIR fittings. Base engine Corvettes delivered for sale in the other 49 states were not equipped with an AIR system nor drilled or tapped for the AIR fittings. In either case the casting numbers are the same.
          Date codes - exhaust manifolds have a cast date code, which follows the alpha-numeric code of the engine block without a year digit. On 350's the date can be seen with a mirror on the portion of the manifold that sticks up above the head. The date is not usually visible with the manifolds installed and therefore is not judged.
          Hope this helps.
          Roy
          • Doug J.
            • April 1, 2005
            • 140
            Re: birthday
            Check the tag in the door jamb. Your car was built at the end of Jan. '72. It should have an "F" and two numbers after the word CHEVROLET in the upper right hand corner of the tag. The "F" being for January and the two numbers being the day in January. That be the build date.
              • 15573
              Re: birthday
              John,
              Why not look at the date on the trim tag? That is the date the judges will use when judging your car.
              All the birthday books are just a waste for C3s. Those books are designed for the earlier cars where the build date is either non-existent or because the body might have been built other than at St. Louis the body build date does not sequence with the VIN.
              • Rob M.
                NCRS IT Developer
                • January 1, 2004
                • 12695
                Re: birthday
                C3 Registry:
                Approximate birthday 1Z37K2S512629: January 31, 1972
                regards,
                Rob.
                Rob.
                NCRS Software Developer
                  • 15573
                  Re: birthday
                  John,
                  Would you be kind enough to PM me the date on yout trim tag, or post it here so I can add it to my records?
